Zanussi DCS 12W – Tabletop Dishwasher Not Draining
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Zanussi DCS 12W – Tabletop Dishwasher Not Draining
  • #53144
    salfordspam
    I just got this second hand from a friend who said she’d had no problems with it at all. I’ve used it twice and it won’t drain at the end of the cycle. I’ve checked the instruction manual and other posts in this forum. There doesn’t seem to be any blockage, water heats fine, washes ok etc. Any ideas please?
    Thanks 😕
    #314570
    Re: Zanussi DCS 12W – Tabletop Dishwasher Not Draining
    Presumably the drain pump is blocked or has failed. The panel underneath can be removed to access the drain pump.
    Power off first.
    salfordspam
    Thanks for the advice – I’ll have a look and let you know what I find.
    #314572
    salfordspam
    Penguin45 wrote:Presumably the drain pump is blocked or has failed. The panel underneath can be removed to access the drain pump.
    Power off first.
    Do I remove the panel from the inside or by turning the thing upside down please? Thanks
    #314573
    Pop a couple of towels down and lay it on its side is probably the easiest way.
    salfordspam
    Thanks! Sorted 😀
