Zanussi DCS studioline : gets stuck when emptying
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Zanussi DCS studioline : gets stuck when emptying
  • #12257
    mcnash
    Dishwasher gets stuck part way through cycle – rinses, then empties – but keeps trying to empty more. Opening door does not operate cut-off, pressing power switch has no effect – only way to stop machine is to turn off at mains.
    I’ve tried disconnecting water and hitting water inlet (see post a few days ago for a different model), removing easily accessible screws inside and cleaning up – that solved the problem for about half a cycle. Any suggestions please? Do the syphons need cleaning (previous post)? And if so, where do I find them? Thanks.
    #148722
    Dave_Conway
    Re: Zanussi DCS studioline : gets stuck when emptying
    The flood protection is activated basically, it makes the drain pump run cotinuously. I would imagine the base is full of water.
    The leak will need to be investigated of course, I would suggest an engineer in all honesty, check Repairs@ for one 🙂
    If you decide to go further yourself, power off 1st :zap:
    #148723
    mcnash
    OK – thanks for the advice
