Zanussi DCS12W stuck on pumping out
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Zanussi DCS12W stuck on pumping out
  • #9774
    dolphinit
    I have a Zanussi DCS12W and having a problem.
    It seems to be stuck on pumping out. Ive checked and the water is going out ok.
    Have tried leaving it unplugged for a while and made sure everything i can get to is cleaned. Tried moving the dial round to advance the program and the ‘running’ light only shows at parts of the program. The dial does still move by itself, but continously tries to pump out.
    Any ideas? 🙄
    #135783
    Re: Zanussi DCS12W stuck on pumping out
    Ah, the table top job. Pull the plug, gently tip the machine back to about 25 degrees and mop up the water which runs out of the base. Next, check that the locking ring around the neck of the salt container cap (not the cap itself) is absolutely tight – they are so and soes for leaks in that area.
    If it does it again, get some pro help – check Directories or Repairs@ for an engineer in your area.
    Ensure plug is pulled before doing anything……….
    dolphinit
    Thanks for advice. It seems to be working ok now. 😀
    #135785
    Perez
    Just had the same problem with my recently purchased Zanussi DCS12W dishwasher – thanks to Google and this site I’ve managed to fix the problem, so thought I’d sign up and say THANKS! 😀
    #135786
    kawasakikr1
    Hi, i’ve also just had the same problem, and just signed up to say thanks.
    #135787
    For future readers (and those who keep bringing this old ‘un back to life), do not use tablets in this machine – you are over-dosing it by a factor of three. Tablets are meant for full sized, 12 setting machines and will froth like crazy. These little baby ones should only ever be run on powder, with a very reduced dose.
