Zanussi DE540x
  • #26817
    brett1611
    Machine failed to heat. I’ve checked the heater and it’s fine. The brown wire from it goes to a small pressure/safety stat and the orange goes to the top pcb.
    I took the pcb apart as much as poss but nothing looks that obvious. But couldn’t get to see the soldered section. Could this fault be the pcb not sending power to the heater or is the pressure stat known to go faulty?
    Thanks any help will be great
    Brett
    #211487
    Re: Zanussi DE540x
    Dry/burnt out relay joint on PCB.
