Re: Zanussi DE540X flood protection is active
It means that water has leaked into the undertray of the machine and the float switch has been tripped. Drain it and the machine will work. However, you will need to find the leak…… Start at what was done last – the tube heater. Clips on correctly? No other hoses disturbed? Also check where the pipe for the upper spray feed joins the tub on the side – it weeps quite regularly.
Power off for anything other than observation, please.
