Zanussi DE6544 flashing lights?
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Zanussi DE6544 flashing lights?
  • #13041
    MartinA
    Grateful if someone could help me with this.
    I’ve got a Zanussi DE6544.
    When I try to start the wash cycle the SID & Normal lights flash but there are no other signs of activity from pumps etc..
    This happened a couple of days ago and I removed the bowl filter, took off the pump impellor cover and cleaned out the green filter thats inside the bowl. Did’nt fix it immediately, but after pulling on the drain pipe it burst into life. Worked OK for a while but its failed again with the same symptoms.
    I reckon its a blockage somewhere, but not sure where.
    Are there other filters I’ve missed?
    Many thanks for the help.
    #152781
    Dave_Conway
    Re: Zanussi DE6544 flashing lights?
    Can you post up the PNC please from the rating plate around the door, there are a few versions of this model.
    Thanks.
    #152782
    MartinA
    Hi Dave,
    PNC 911888012/01
    Model 0E6544
    Type 911N81 8F
    Thanks,
    Dave_Conway
    Ah, it’s one of those.
    From the bank of lights, they should be mapped out with 3 vertical then 5 vertical
    Can you indicate which are the flashing one’s please.
    #152784
    MartinA
    Hi Dave,
    Must have been chewing on dishwasher tablets 😯
    Why I said the SIDS and Normal lights flash I don’t know!
    The top two lamps on the 5 vertical are flashing. That is the wash and dry symbols. The other three are off.
    I think you meant that the bank of 3 lights are horizontal not vertical?
    There are also 4 of them. labeled right to left Economy, Quick, Normal and intensive (SID).
    Only the selected program light is on. All others are off.
    Just had another play with this and found that the Quick wash program only lights up the top vertical lamp. All others still light the top two.
    Hope I did’nt confuse you too much with my initial post.
    Martin.
    #152785
    Dave_Conway
    I think you’re going to have to take a photo of the control panel and email it to me, indicating which lights are flashing 😉
