This machine starts up,drain pump working and humming from intake valve as if asking for water.No water comes in.Coils ok.Water supply ok.After a few minutes prog.light and dry cycle light flash repeatedly and consistently?? Vot can this mean???
I’m convinced this is what is wrong with my dishwasher, however I can’t get the side panel fully off to see the IWMS. I have taken the screws at the back off, and one on the side under the top. Is brute force now required to prize the panel off, or have I missed a screw?
There are retaining screws behind the kick panel. That’s held by two screws. Get rid of that, then you can access them. Once undone, it’s a lift and pull to release the panel.
Penguin45 wrote:There are retaining screws behind the kick panel. That’s held by two screws. Get rid of that, then you can access them. Once undone, it’s a lift and pull to release the panel.
Cheers, got the panel off now. Just trying to work out how to remove the unit ❓
well, I think I have broken it. :rolls: I popped the plug off to get rid of what I though twas brown gunk, when it seems it is in fact the water softner. I have hosed all of this out now, and the plug will not go back on. Any suggestions how I can rescue the situation?
