M/c sprang a leak – hose out of heater to pipe up to top sprayarm and stopped with flod prot leds flashing. Whipped the covers off and switched on, worked and found leak. Tried a bit of LSX silicone as a temp repair, tipped it over enough to check heater just in case. OK. Tried again, m/c worked but silicone failed. Switched off and replaced hose / pipe assy.
Now m/c starts, tries to pump out (if I pour water into the dishwasher it does pump out) and after about 1 1/2 mins goes to flood protection lockout. Does not fill and no mains volts on water fill solenoid. There’s no sump on this m/c – the split hose was on the rhs above the floor and all the water went on the floor. I have tried tipping it on its lhs almost to the floor and as far as I can see there is no hidden sump. (Am I right?) The IWMS network looks very clean – no black gunk anywhere.
Is there a reset code I need to enter or am I looking at a mechanical / electrical issue?
Thanks, Hopper
