ZANUSSI DE6744s Program Lock
Home Forums Public Support Forums Help And Support Dishwasher Help Forum ZANUSSI DE6744s Program Lock
  • #17015
    TerryGB
    Problem resolution required, machine has stopped part way through a program (at the drying phase on the 70° SID program) holding the button to cancel the program does not work. I have shut machine off and unplugged it but there is still no change, the machine had originally not started its program but burst in to life later (not due to 3 6 or 9 hour delay selection).
    The machine has been dismantled with the exception of turning it on its back to examine the underside pipe work or removing the IWMS moulding, as this is the extreme measure that I would prefer to avoid.
    If anyone can offer the advice I would appreciate it. The message posts have been evaluated and although some of them did through some light I have not found the answer.
    The PNC is 911888019
    #172557
    Re: ZANUSSI DE6744s Program Lock
    Did it stop “dead”, or did you get flashing LEDs?
    TerryGB
    Stpped dead with no flashing led, unless cabinet door is open.
    #172559
    Door switch would leave power light on. Sounds more like power supply on computer board has died, or some board related failure.
    Power off if investigating.
    TerryGB
    I feared that 🙁 as this is not the first time it has happened, previously though the machine recovered itself after just being left alone.
    Any idea on the cost of a replacement? or what I need to search for one from here?
    Thanks for your valued help on this.
    #172561
    Board is p/no 1525785-13/3 – about £83 plus VAT & P+P. You can order through spares@ukwhitegoods.co.uk quoting the part number.
    Due to the expense, be very sure that this is what is actually required…… Time for some pro help, perhaps?
    TerryGB
    Or maybe just replace the machine.
    Thank you again for your help.
