My Zanussi DE6754 dishwasher has just started flashing the programme selected light and Dry Cycle light as it has reached the dry cycle and is doing nothing. I have tried to select another wash programme and it has halted at the same step. It has washed and the water has been warm as it is steaming.
Does anyone know if this is RIP for the dishwasher or an easily rectified problem??
Re: Zanussi DE6754 Dishwasher Flashing Lights on Dry Cycle
I think you’ll find it’s no drain detected in the time allowed. Most likely you have a blockage. Check sink coupling (if appropriate), check drain hose is not kinked or trapped, failing that the drain pump is underneath…….
