Zanussi DE6850
  • #17459
    Ishtar
    I’m having a problem with my Zanussi in that it isn’t running the drying cycle at all and the water isn’t getting very hot – probably not even to lukewarm.
    I’d be grateful for any advice/suggestions before I call in the engineer.
    Thanks in advance
    #174450
    Re: Zanussi DE6850
    50/50 shot on this one – either heater or control board will be at fault.
    Check this thread:
    http://www.ukwhitegoods.co.uk/modules.p … c&start=30
    Basically the same appliance. Power off is investgating please.
    Ishtar
    Re: Zanussi DE6850
    Have looked at the PCB and it is pretty obvious that this is where the fault lies as there is a bit(!) of a scorch mark 😯 . Anyhow, the problem seems to be a dry solder joint, which we can fix. Hopefully the relay hasn’t suffered as well….
    Thanks a lot for your help – sounds mad but without this site we wouldn’t even have looked for the problem, just called out an engineer.
    Cheers
