Zanussi DE6854
  • #25538
    Steven
    Zanussi dishwasher DE6854 9(11915012/01) is there a test programe on this model?
    Complaint not hot at end of wash and was on for longer than normal, customer thought it just hadnt pump out so bailed it.
    Check & cleared programe fills /washes / dispenser releases / pumps / water level all seems ok, but does not seem to heat, checked the heatertube & pcb and in past usally solder joint on pcb but all looks ok.
    Are there any other stats?
    Many thanks
    Steven
    #206280
    cab
    Re: Zanussi DE6854
    Hi, check your pm.
    cab
    #206281
    Steven
    Re: Zanussi DE6854
    Nothing through on Pm
    #206282
    cab
    Re: Zanussi DE6854
    Check you inbox!
    cab
    #206283
    delta01
    Re: Zanussi DE6854
    hi guys i have exactly the same problem with same model d/w could you advise please
    john
    #206284
    Steven
    Re: Zanussi DE6854
    This one was a pcb fault, replaced it, have had no come back, so must have sorted it.
    If you need the service manual let me have your pm
    Steven
    #206285
    AMS
    Re: Zanussi DE6854
    This is usually a blown joint on the board. A dab of solder usually does the trick.
    delta01
    Re: Zanussi DE6854
    thanks guys it was a dry joint sorted
