Hello again, ive got a zan d/w DE6855 with no heat, Checked heater, ok wiring apperas ok is it controlled by the thermistor on the bottom of the filter sump? Thanks for the help.
Hi, Had one like this myself a while ago. Can’t remember the model number though. It turned out to be a dry joint on the heater relay. I resolderd it and it worked fine. Hope this is of some help to you.
Good luck.
Ashby.
