Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Zanussi DE6965 AL6 error code! Machine not draining.
- This topic has 9 replies, 3 voices, and was last updated 18 years, 10 months ago by
Betty Swallocks.
June 10, 2007 at 9:20 pm #28012
Betty Swallocks
ParticipantThe machine stops with this error code. I have checked all the obvious things :- blockages etc. Stripped the inner filter out and removed a housing and removed some food debris. Checked the pump and it is working fine. No other obstruction I can see.
Cheers
Chris
June 11, 2007 at 7:35 pm #216525Penguin45
ParticipantRe: Zanussi DE6965 AL6 error code! Machine not draining.
You haven’t mentioned whether or not it does actually drain the water out…….
penguin45.
June 12, 2007 at 10:29 am #216526Betty Swallocks
Yes, the machine pumps the water out perfectly. The pump is performing fine. I wonder whether it is a sensor for anti flooding? After the machine has done a wash it then drains ok as you can see and hear the water being pumped out and before it refills it will display an AL6 (machine is not draining).
Cheers
Chris
June 12, 2007 at 10:35 am #216527Penguin45
Problem will be in the water level control department then. It thinks it’s still full. Standartd fault is the fill matrix on the left hand side sludging up.
This:
http://www.ukwhitegoods.co.uk/modules.p … ge&pid=104
explains rather better. Yours is the IWMS machine.Penguin45.
June 12, 2007 at 5:06 pm #216528dna
this will cure your problem Composition of ATB Pressure Switch conversion Kit: 5027 86 65-00/0
June 12, 2007 at 6:05 pm #216529Penguin45
No it won’t, dna. This model uses two different IWMS manifolds, depending on the pnc number, neither of which is the part number you have quoted.
If you are a member of the trade, please do us the courtesy of applying for trade access to UKW. Contact admin@ukwhitegoods.co.uk with your business details.
Moderator.June 13, 2007 at 1:52 pm #216530Betty Swallocks
Thanks alot guys for the response, I will investigate!
Cheers
Chris
June 14, 2007 at 2:39 pm #216531dna
PENGUIN this isnt the part number of the iwms its the part number for a modification kit which does cure the problem it adds a new pressure switch and a double valve. the pressure switch acts as an overfill pressure switch and the double valve well its a double valve i am a member of the trade part actullay just thought i was helping SORRY!!!!!!!
June 14, 2007 at 2:45 pm #216532dna
And yes penguin this will cure the prblem even if the iwms is sludged up. have done at least 100 of the kits and it works every time, thank you.
June 19, 2007 at 6:53 pm #216533Betty Swallocks
I removed the IWMS and flushed it through with a hosepipe and unblocked the sludge from within the galleries, checked the pressure switches and re-assembled the IWMS into the machine. Everything working as it should do 😀 .
Many thanks to all who helped…..I appreciate it!
Until the next time
Chris
