Zanussi DE6965 buttons stuck
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Zanussi DE6965 buttons stuck
  • #25740
    stephen66
    Hello,
    I’ve had this dishwasher a few years and because I’m always using the “normal” wash, the button has got worn out and is now stuck in the on position. I would guess I’m outside the warranty, so can anyone tell me:
    Does the swicth need to be replaced? I presume it’s spring-loaded and the spring has failed?
    If so, are the switches expensive?
    And finally, if I do have to change the switches, is this something a member of the public can DIY?
    Thanks.
    #207398
    Re: Zanussi DE6965 buttons stuck
    I hope you’re sitting down…….
    If the buttons in the control panel are broken, you need to replace the entire control panel complete – about £60.
    If it’s the touch controls of the display boards themselves, you need to replace the pcbs – about £65.
    Plus VAT and postage – spares@ukwhitegoods.co.uk will be able to supply if required.
