Re: Zanussi Defrost Heater
Done this one today. In case anyones interested, heres my advise. First of all, although it looks very fiddly, rest assured, it is VERY VERY fiddly. Wear 2 pairs of rubber gloves and have some plasters ready. After removing plastic casing to access evaporator use telescopic mirror to see heater connection plug at back of freezer and unplug. Note position of heater then remove from evaporator avoiding cuts from razor sharp fins. Replace with new heater, clipping back into position again avoiding too many cuts from razor sharp fins. Oh and by the way, dont worry too much about bending and squashing all the fins as you clip the new heater home, (its the only way you’ll get it clipped in). Be very careful while doing this, not to kink the evaporator return pipe or capillary as these are the only things holding the evaporator up while your wrestling with it. Be careful also not to cut the heater wires on the sharp fins too. Put back casing, wash blood from hands, apply plasters. Job done! Doddle! 😆
Subs
