Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Zanussi DES959
- This topic has 5 replies, 5 voices, and was last updated 22 years, 2 months ago by
Kentish.
January 19, 2004 at 9:46 pm #5075
Kentish
ParticipantI have an interesting fault that occurs with a Zanussi DES 959, pd no 911886007 d/w whereby the fault code AL3 appears, after the dishwasher has been on for about 50 mins of the 65 degree program (which is indicated at 92 min length). It then stops full of water.
However if it is put onto a rinse-hold program it works fine.When the fault code appears, the rinse LED is still lit, and detergent flap still closed indicating that the d/w hasnt drained from the pre-rinse part of the 65deg program.
So far I cant see anything obvious, but knowing Zanussi from old there is usually a constant fault related somewhere.
Does anyone have an idea or seen this symptom before?Cheers guys.
January 20, 2004 at 8:43 am #108657Dave_Conway
ParticipantRe: Zanussi DES959
Kentish, AL3 is a “water heating timeout” error, where the water hasn’t reached the correct temperature within 45 minutes. Here are the possible scenarios from the Zanussi service manual.
a) Heating element interrupted
b) Safety thermostat open
c) Wiring interrupted / disconnected
d) NTC sensor incorrectly positioned / Poor
thermal contact
e) Insufficient water circulationHope that helps a bit.
January 20, 2004 at 4:11 pm #108658Kentish
Aaaahhhhhhhhhhh….. but why doesnt it drain and move into the wash section and open the soap flap. Thats is what is really puzzling me.
But thanks for that bit of info.
Kentish
January 20, 2004 at 4:35 pm #108659Martin
I think it probably the most obvious line to check as Dave suggests (his Item a) Heater????????
After it has proceeded some 50 mins as you say, it should have long ago started to wash and released the detergent flap and be well hot by then. I reckon the reason is in the heater circuit somewhere??
January 20, 2004 at 9:12 pm #108660eastlmark
ModeratorRe: Zanussi DES959
Get a magnifier and look VERY carefully for dry joints on the console module. We have had 2 recently of this family (not ness this model number) where this had been the no heat problem. Try around the LOW voltage terminals of the heater relay.
January 20, 2004 at 11:00 pm #108661Alex
If the heater is the “in line” type, look at the toc on the barrel. They tend to be sensitive due to connection inside breaking down. Caused by blocked filters which make the thing overwork.
Complete heater assy. is the fix.
