Zanussi DF 62/26 Ice Build Up in Fridge
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Zanussi DF 62/26 Ice Build Up in Fridge
  • #27603
    Tiger2006
    Zanussi DF 62/26 has served me well. It is an old model but has started to build up a big ball of ice just below the back plate that is inside the fridge, for 5-6 months, otherwise cooling is OK. Within days of defrosting this ice and cleaning the fridge as per instruction manual, it builds up again. In addition, any fresh food touching the walls or left in the salad crispers gets frozen and the salad crispers also get stuck to the bottom of the fridge compartment through a thin ice layer.
    Any solutions/sugestions are welcome?
    #214847
    clivejameson
    Re: Zanussi DF 62/26 Ice Build Up in Fridge
    Unfortunately this is the death nell of your fridge/freezer….however the small bit of good news is that it will not stop actually cooling because of this fault, however the ice-ball will get bigger more and more quickly.
    The cause is the cooling pipes to the fridge are mounted too close to the fridge liner and eventually the steep temperature gradient from the pipes to the liner causes the insulation to fail at that point for which there is no effective cure 🙁
    #214848
    Tiger2006
    Thanks for the reply. I have ordered a Hotpoint RFA52P. Hope this is a good model.
    #214849
    helo_75
    lol
    #214850
    Tiger2006
    Hi helo_75, Do you mean that it is not a good model. Can you suggest one?
    #214851
    Hi Tiger, just do a search in the forums for Hotpoint and/or Indesit as they’re the same thing pretty much. 😉
    We don’t rate them.
    Tiger2006
    Thanks K.
