zanussi diagnostics.
  • #33887
    tradesite
    Would anyone be good enough to telll me how I access the diagnostics on a Zanussi fjs 1225w?
    Cheers.
    Nigel.
    #240474
    tradesite
    Re: zanussi diagnostics.
    Just ordered the diagnostic book from the U.K.W. shop but could do with this info a little sooner.
    Cheers.
    Nigel.
    #240475
    File in your in-box, Nigel.
    PGS
    Nigel why not share the fault and diagnosis with us all cheers Paul.
    #240477
    tradesite
    Fault is, sometimes it displays E90, other times it flashes the start/reset light , other times it does nothing. I have had the board off and can see no visible signs of damage, tightened the connectors and cleaned the terminals, checked the pump, motor etc suspect that there may be a fault with the board but am not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure yet.
    As I was typing this the postman has arrived with my book. must say on first impression it’s a steal for the price am very impressed.
    Will let you know when I eventually find the fault!
    Thanks Penguin 45 for sending me the info!!!!
    Cheers.
    Nigel.
    #240478
    tradesite
    Fault came up as e92 telling me the board was faulty. Checked the price of a new board and then decided to let the scrapman have it as there was no profit in it.
    cheers.
    Nigel.
    #240479
    Alan1476
    HI re E90 Fault. Communication error between boards. Note The blue cable joining them together sometimes that becomes a little lose or contaminated if you change that cable you will find that that will cure your fault. Have done loads of them. 😆 😆
