Zanussi FLE1416W will not start a programme. You set it, press the start button, it pumps out for a few seconds then stops with the start button led flashing. I took the laptop with me and attempted to do the diagnostics procedure. Part of this gets it to display the last alarm condition. This seems to flash some of the last column of lights, led 26 to 33 but I can’t find a list of faults to go with these alarm codes. Is this information to be found elsewhere on the TDS (tedious 😉 ) CD? The functional tests seem to work OK until it gets to the stage where it should pump out and do maximum spin. It pumps out OK but then stops and an alarm comes on. The previous test with 250rpm spin works OK
