ZANUSSI DISH DE6744
  • #17621
    alro
    PROGRAMME SELECTED BUT WILL NOT START
    FITTED NEW CONTROL PANEL WORKS OK FOR 3 MONTHS
    SAME FAULT
    FITTED ANOTHER NEW CONTROL PANEL WORKS OK FOR 4 MONTHS
    SAME FAULT
    HAVE DONE COMPONENT TEST ON PANEL ALL OK
    CAN ANY ONE HELP ME WITH MY PROBLEM
    THANKS
    ALRO
    #175510
    Re: ZANUSSI DISH DE6744
    Hi Alro,
    Welcome aboard…
    Earth leakage causes havoc with these boards – motor and heater are the obvious candidtates.
    Cheers,
    alro
    THANKS CHRIS
    PUT IT OF TILL TUESDAY
    BUT I HAVE MEGGERED ALL COMPONENTS IN THE THING
    NOT A LEAK NEAR MOTOR OR HEATER
    CHEERS ALRO
    #175512
    Dispenser solenoid? Seen one or two of those do strange things…
    alro
    CHRIS CUSTOMER RANG BACK MONDAY TO SAY DISHWASHER WORKING OK AGAIN BUT I AM SURE IT WILL COME BACK IN. LOOKED AT THE TDS DISC WOULD THE MODIFCATION TO THE ANTI FLOOD VALVE BE THE SOLUTION?
    THANKS ALRO
    #175514
    Fill problems would come up as an error (code 5) – top right LED flashing, so Gawd knows what it’s been up to. The IWMS and associated pipework does seem to be a weak spot on this range, but no point in changing it all unless really gunged up.
    I’d keep very quite and my fingers crossed 😀 .
    alro
    chris
    the dishwasher came back with same fault again
    tested all components again solved it after checking
    rinse aid sensor faulty as you said pcb does funny thing
    why it should show the fault that antiflood is on
    thanks for the support
    alro
    #175516
    S1MON
    interesting ive had one with a similar fault, doesnt seem to a definate answer with these……. ill jave a look at that rinse aid sensor. I also turned water pressure down and that caused it to work a few times??
