Zanussi dishwasher
  • #51957
    cornflakes
    model ZDT 6053
    911939002
    client says unit is not heating up hence wet pots after cycle
    are we looking at heating element or other circuit problem
    as its fullt integrated and floor tiles not under unit, would like to know
    before struggling to remove to investigate further
    gracias
    #310110
    loopey
    Re: Zanussi dishwasher
    1st place i would look at is pcb for dry joint ?
    #310111
    Owain84
    try looking at module in door for dry joint on board
    cornflakes
    hi thanks for tips regarding relay on pcb
    sod laws says it never is the first thing you thought it was
    removed unit..240 volts at heater termionals after pre was
    heater nearly open circuit on megger test
    so conclusion in line heater
    now the best bit HOW IS IT REMOVED without seperating base unit from cabinet…tried long nose right angle pliers on clips..you cant get deep enough to remove sump clips and circulation pump clips
    is ther a short cut to removal of element
    or method of removal
    thanks
    #310113
    cornflakes wrote: HOW IS IT REMOVED without seperating base unit from cabinet…
    If you mean without access to bottom by pulling it out, then I think you’re asking the impossible. Difficult enough with machine on it’s side and baseplate off.
    Mike.
    #310114
    cornflakes
    i was trying to avoid spitting base from cabinet
    as there is no access into base area other than restricted from the sides
    doe this model seperate like bosch units
    Thankks
    #310115
    Have sent you an ickle file to have a read of.
