Zanussi dishwasher
  • #68771
    cornflakes
    have looked at
    Zanussi ZDT6053 prod No: 91139202/02
    it appears as if the rinse aid dispenser is leaking when closed
    it is difficult to see exactly where it is leaking from
    the rubber gasket seems very soft and will not fit or hold in its recess on the dispenser lid
    when dispenser lid is in the closed position, if you put door to nearly closed,re open there is a slight trickle of liquiud visible.
    I suspect its the gasket but thought I would check it out as I have never come across a similar proplem in the past.
    thanks for any help
    Graham
    #372714
    Re: Zanussi dishwasher
    I’m not sure that the rinse aid gasket is available separately? It’s not listed anyways…. 🙁
    Rinse aid is very corrosive so I’m not surprised and therefore suggest curing the problem by fitting a complete new dispenser assy (50285882002) and be done :tup: 😀
