Zanussi dishwasher
  • #11869
    Anitap
    Hi – after nearly 10 years of exceptional hard work my Zanussi has turned on me!
    When I turn it on, its showing the cycle time as about double the usual amount of minutes. I switched it on before work, came home at 5pm and the dishes were still dirty!
    The water doesn’t seem to drain properly – I’ve cleaned the filter in the bottom. Any suggestions would be very much appreciated!
    Many thanks, Anita Parkinson.
    #146988
    Re: Siemens extraklasse SE26293GB/13
    Is it heating? Programme hangs until temperature is reached.
    Anitap
    It seems to be getting hot, no problem.
    #146990
    First of all from what you say I suspect you haven’t been topping up the salt quite as regularly as you should? Because from the symptoms, I would suspect it is crudded up inside and needs first of all a good clean with a dishwasher cleaning tablet (or solution), topping up fully with dishwasher salt and if that fails, to get a local engineer in to clean and service it 😉
    #146991
    Anitap
    There is still plenty of salt in the dispenser, and the little S hasn’t come up for a while!
    I guess I’ll try the engineer 🙂
    Thanks for your help 😀
    #146992
    Anitap wrote:I guess I’ll try the engineer
    try our Repairs@ for a local engineer 😉
    #146993
    Anitap
    will do Martin, thanks 8)
