hi thanks for the reply does the flood protection not only work if there was a leak or the dishwasher over filled and would bring in the pump to clear the the over fill and what do you mean by a choked water fill matrix and where do i find it and where do i find zaunissi iwms thanks penguin 45. fase tester
hi thanks for your reply do you mean the pressure switch is blocked and where do you find the syphon tubes the problum would have nothing to do with the electronics or the control panell need resetting thanks lotusray. fase tester 😕
