have a DE6744 Zanussi dishwasher when switch on 3rd led & 9&10 led flashing can not cancel programme .I have fitted a new control pcb in dec 05 problem went away, came back in april 06 another pcb problem went away I have done a full component test cycle all working ok seems like another pcb required ANY IDEAS would help me just can not beleive what am I missing.
thanks for the info sheets chris, but have already seen the work on the T D S dics but I still can not resolve the problem will try another PCB control board.
9 & 10 indicate antiflood activated, but if no water in base is refers to pressure switch not remaining `FULL` until next drain, so is there a leak on the pressure system or more probably is the machine autosyphoning dropping the water level 😕
