Re: Zanussi dishwasher DE6965 AL7 fault code
Dave_Conway wrote:According to Zanussi it means that there is no water circulation, which could be one of a few different things causing it.
Check the filter for blockages, apart from that you will more than likely need an enginner to check the relevent components for you.
Hope that helps a bit anyway
Is that the water inlet filter or the internal debris filters, is there anything else I can look at / check before calling out an engineer (the machine is out and part in bits anyway)
