Re: Zanussi dishwasher ZDT6252
Have you removed and reconnected this module to eradicate possible bad edge connections? If they are OK, then the PCB could be generating a fault code – so just for reference:-
Fault code diagnostic lights lit (left to right) L1 to L5:-
L1 – time out on fill.
L2 – excess time between empty and subsequent refilling ie: blocked pressure system.
L1 and L2 together – motor inoperative or blocked (excess current drawn).
L3 – temperature sensor open or short – circuit. Sensor range between -5c and 80c. Resistance of sensor should measure between 209.2K ohms and 5.3K ohms.
L4 – time out on heating cycle.
L5 – time out on drain.
If the above all checks out OK, the PCB has snuffed it. 🙁
Hope that helps,
Steve.
