Zanussi Dishwasher ZDT6252
  • #59978
    thankevans
    Hi has anyone got the fault codes for this model
    #340260
    Criscold
    Re: Zanussi Dishwasher ZDT6252
    You Have Mail
    #340261
    twicknix
    Any chance I can have a fault code? I have this dishwasher with two lights flashing – rinse&hold and intensive.
    Carried out basic electrical checks – all passed. Not attmpted to check heater as it’s built in appliance.
    #340262
    Criscold
    PM your email
    Colin
    #340263
    twicknix
    turned out that it was blocked sump. cleared out the crud and plastics. Supplied descaler and salt to client as it was heavily scaled.
    client thought 3in1 tablet was enough, clearly it was not enough.
    #340264
    twicknix
    I just had this dreaded phone call saying that the dishwasher is not working after I fixed it yesterday.
    It did work when I left, clearly when they started to use it and it stopped halfway with 5th light flashing – drain time out. First job tomorrow – not summat I would have liked to start the day off!
    I searched on this forum and could not find anything of use, it implies that this machine does not have a drain pump rather using circulation pump and redirected water to drain using a system of valves. (I looked on spare parts websites) It was full of crud on the last visit and very heavily scaled up but I thought I removed the bulk of it. In hindsight I should have put in degreaser but there’s so much you can persuade the client to take the products.
    The impeller was sticky yesterday but I freed it. So I am wondering if new impeller is needed or something more drastic?
    Does it involve taking the machine out or is it summat I can do inside the sump?
    Can anyone advise me on how to reset the dishwasher other than turn power off? Also how to program the d/w to drain?
    Thanks – Matt
    #340265
    Maybe the descaler you gave them loosened up a lot of scales and they built up in the drainage. Not familiar with model but some of the old ones used the main circulation motor in reverse to effect drainage. Trouble was the reverse impellor blades tended to get stripped off. Quite easy to access motors on them though.
    Mike.
    #340266
    mikeday1
    Anyone got a fault code list for this model
    #340267
    twicknix
    Sorry I didn’t have the fault codes for this model. I think it was cured by degreaser.
    I can’t remember if I actually received the fault codes. Will check my files.
