zanussi door wont lock Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › zanussi door wont lock This topic has 8 replies, 3 voices, and was last updated 19 years, 8 months ago by nigelr. Viewing 9 posts - 1 through 9 (of 9 total) Author Posts August 15, 2006 at 11:11 pm #19981 nigelrParticipant i have a zanussi fs1555w that wont run, the interlock is new but the lock light still not on, the interlock fires three times then error code for door open. hellp August 15, 2006 at 11:15 pm #185286 gegsyParticipant Re: zanussi door wont lock Possible spring tension of striker in door the culprit. Greg August 15, 2006 at 11:21 pm #185287 Penguin45Participant Re: zanussi door wont lock Unlikely, Gegsy – board rather more likely candidate, especially if the original lock actually failed. Penguin45. August 15, 2006 at 11:36 pm #185288 gegsyParticipant Re: zanussi door wont lock Yea think you right there. Nigel, can you post up all the numbers after the model number off the rating plate so we can assist you further? Greg August 16, 2006 at 10:08 pm #185289 nigelrParticipant Re: zanussi door wont lock thanks for your interest. Mod fs1555w, Typep6848646, prod No 914791191/00 August 16, 2006 at 10:50 pm #185290 gegsyParticipant Re: zanussi door wont lock If its the PCB as P45 suggested then its p/no DST973914791191005 around the £160 mark. Greg August 16, 2006 at 11:26 pm #185291 Penguin45Participant Re: zanussi door wont lock Nasty – does it have to be programmed as well? If so, it’s engineer time…….. Penguin45. August 16, 2006 at 11:30 pm #185292 gegsyParticipant Re: zanussi door wont lock Says pre-programmed, still fiddly to fit though. Engineer may be best course to take me thinks. Greg August 19, 2006 at 5:15 pm #185293 nigelrParticipant Re: zanussi door wont lock Thanks alot for the input guys. it was the board, broken track fixed it with a conductive pen,you made my misses very happy. Nigel Author Posts Viewing 9 posts - 1 through 9 (of 9 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
