Zanussi double oven fault with bottom oven
Home Forums Public Support Forums General Enquiries And Questions Zanussi double oven fault with bottom oven
  • #71351
    timble
    HELLO i HAVE A PROBLEM WITH A ZANUSSI DOUBLE OVEN. THE FAN ELEMENT BLEW IN THE BOTTOM OVEN. I HAVE REPLACED IT WITH A NEW ZANUSSI ELEMENT .tHE OVEN WONT COME ON THE NEON DOESNT LIGHT FAN DOESNT WORK .tHERE IS NO LIVE AT THE ELEMENT OR FAN. tHE TOP OVEN IS FINE AND WORKS NORMALLY the digital clock resets to manual after a power switch off according to manual so its not atimer issue i dont think. Solve this please thankyou
    #380813
    captaincaveman1
    Re: Zanussi double oven fault with bottom oven
    You always have to re-set the clock if you switch it off it doe’s not re-set itself so this is the first thing to check so set the correct time if the fault still persists then you’ve been unlucky in that the element will also of blown the oven thermostat.
    #380814
    timble
    Thanks for that.. Ill check out the clock Timble
