Visited a Zanussi built under double oven Model – ZHQ575X
The Main oven selector switch was burnt out.
A search on the connections website shows 3 different switches, one that costs 62.00 the others are 17.00.
Does anyone know if any of the switches will work or is the wiring harnes different for each switch?
Any help gratefully recieved.
would need the product code or more importantly, the numbers after the product code ie: 944171208 00 or 01 and can you confirm if the switch you need is the lower or upper of the 2 on the control panel?
