Zanussi Double Oven Tripping RCD
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Zanussi Double Oven Tripping RCD
  • #95056
    Richard_56
    Hi I have a Zanussi ZOD35702XK Double oven.
    The lower oven works perfectly on all settings.
    The top oven however trips the RCD the oven circuit is on. The BCO doesn’t trip, but the RCD does.
    When the top oven is turned on it will start to heat up fine but when the predefined temperature is met the RCD is tripped. I’ve tried it at various temperatures, 50°C /200°C, doesn’t seem to matter, it will continue to heat up until it reaches the set temp.
    Will this be a faulty Thermostat or the heating element do you think?
    Can you point me towards the best place to buy spares for this?
    Thanks in advance,
    Richard
    #459228
    element most probably
    as for parts we would need the complete Enr number to be certain but there are 2 elements in the top oven. the visible one which also acts as a grill and another one under the floor
    its likely the one under the floor is
    https://shop.ukwhitegoods.co.uk/3192083016-base-oven-heating-element
    but it would need confirmation
