zanussi drain hose
  • #50337
    fridayfriday
    I’ve got a zanussi zwf 14070 w1 washing machine but the drain hose hasn’t got the rubber connector on the end so I’m left with the hard plastic pipe. Do you now where i can purchase these end connectors ? As I’m looking for one that’s 19mm ?
    If not I guess that my only option is to replace the whole drain hose with a new one. After taking the top off the machine the hose feeds down to the bottom and to the front. If I do need a new hose can you tell me the best way to change it?
    #304479
    Dales-Electronic
    Re: zanussi drain hose
    What are are you trying to connect it to? Is it going into a standpipe or to a connector under the sink or has it just broken off at the back of the washing machine?
    #304480
    fridayfriday
    I’m trying to connect it to a connector under the worktop which then extends into the drain pipe.
