zanussi drain pumps
  • #54143
    funbobby
    anyone had any joy getting the filter out on these when the front detaches? wondered if anyone had developed a knack as there is nothing to pull on these. seem to be getting a run and changing the entire housing which is a fiddly job!
    #318561
    Re: zanussi drain pumps
    Which style pump are you referring to? The later ‘self cleaning’ type with the emergency drain pipe attached, or the earlier ones with the curved filter?
    #318562
    funbobby
    the straight ones, nothing to grip on the filter to pull it out, daft bleedin design.
    #318563
    If you already have a new one to replace it you can screw in a couple of self tappers and pull on them.
