Zanussi dryer cutting out.???
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi dryer cutting out.???
  • #86224
    ZDC47100W. Pnc: 916094517/09
    Tried it without clothes but set to a timed dry period. As the customer stated the dryer stopped completely after about five or six minutes. Switched off and then switched back on within a few seconds and it started to run once again, tumbling and heating correctly so don’t think it could be motor overload related.
    Tried to run diagnostics but got a strange ‘non error code’
    The start button is flashing between red & green with virtually no pause, just red/green , red/green continuously.
    Condenser etc all clear.
    Any thoughts?
    #430588
    Seamy
    Re: Zanussi dryer cutting out.???
    Heater goes out on them sometimes if dryer is used constant without cool down period. NTC needs to cool down.
    Check rear felt bearing/seal, if its off or distorted air from fan is not directed over heater and again heater goes out, open circuit but this normally throws up a fault E62
    #430589
    Thanks Seamy, machine is in a garage and AFAIK they don’t stop it mid cycle.
    Any reason why the diagnostics wouldn’t run correctly, it just flashes red/green continuously without a pause???
    Seamy
    iadom wrote:Thanks Seamy, machine is in a garage and AFAIK they don’t stop it mid cycle.
    Diagnostics may not run correctly if it has not been selected correctly, corrupt board, short circuit of component etc
