hi guys,
TC7102W
916092502/00
machine is dead apart from when you press the start switch the “empty water tank” light comes on.
checked all usual faults, stats, on’off switch, microswitch at the bottom kick strip, door int. seems fine.
had a search on the forum and it sounds like it could be the float switch that is stuck/faulty.
does any one agree?
if it is, can any one point me in the right direction for removing it?
is it a drum out job?
a part number would be good as well if possible.
thanks
john
