You’ve posted this in the only Public Forum that doesn’t tell you to post the model number! There are literally hundreds of Zanussi w/d’s over the years.
Assuming it to be a reasonably recent model, there is a manually resettable safety stat on the top housing. However, if it clicks to reset when pushed, you have to find out why it tripped. Is the fan running? Is the condenser valve feeding? Is the filter clear? Is the condenser housing full of fluff?
If you have any doubts as to your abilities, send for an engineer. Check the Directories section for a local UKW engineer, or pop your postcode up in here and someone will pick up on it.
Whatever you do, Pull The Plug First!
