I have the above dryer and the belt has snapped.
Cant get a new one for 48hrs so have taken the back off in readiness of fitting.
When removing the circlip 2 washers dropped out and I cant remember where they where fitted 😡
Is there somewhere on line where I can see a schematic of the bits and pieces ?
a quick google showed nothing
Thanks in advance
When you removed the circlip, was it sitting in a groove in the drum shaft that goes though the rear bearing? If so, the 2 metal shims go between the circlip & the rear drum bearing.
If you can fit a bicycle chain, you can do the belt. The only things to do aside from isolating the appliance from the mains supply is to correctly route the belt around the tensioning pulley on the motor although this is just a matter of common sense as if you don’t, the belt is slacker than my mother in law’s knickers. 😆
