Zanussi dryer ZDC37200W stops after 10mins??
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi dryer ZDC37200W stops after 10mins??
  • #84518
    asp11
    Hello – I have checked the previous posts but did not find a solution to my problem.
    This machine runs fine for about 10mins, it turns and heats fine but then stops, when I believe it would be going into the reverse direction. After a few seconds the start light flashes in no obvious pattern and the “tank light” comes on all the time with a bleeping sound.
    If you cancel that setting and start again, it will but only for a short period. ANY IDEAS?
    Brett
    #425857
    Re: Zanussi dryer ZDC37200W stops after 10mins??
    Burnt/arcing contacts on float microswitch is one possibility.
    #425858
    asp11
    I didn’t actually check that but when it is working the water does collect in the bottle, because I emptied it today?
    #425859
    asp11
    I was thinking the fault might be the pcb not going into reverse but its expensive, so thought I would ask you guys first!!
    #425860
    martinm
    its most likely the float sticking and then bringing on the tank full light…had quite a few of them with the float sticking
    #425861
    asp11
    Ok cool. Thanks to you both
