Re: Zanussi dw 907 won’t fill up
Funny that, 2 of you with the same fault on the same series d/washer came in within a minute.
In both cases it sounds like the water valve has “locked out”.
Quick fix.. 1) Turn off the tap/water supply. 2) Unscrew the hose to release the water pressure. 3) Give the water inlet valve at the lower rear of the machine where the hose is connected a sharp tap with the handle of a screwdriver. That will release the shut off.
Now you need to investigate the reason why.
1) Remove the large filter inside the D/Washer. 2) Look at about 4 o-clock and you will see a semi transparent cap held on with a single stainless screw. 3) Remove this cap and pull out the 2 syphons, 1 at a time. 4) Shake out any excess water and clean any grease form the syphon. 5) Put it back together, reconnect the inlet hose and give it a run on rinse and hold. (Prog D) 6) If no joy, then go to repairs @, you have done your best.
That was a good range of D/Washer and worth keeping running.
Alex
