My dishwasher is not rinsing i’ve cleaned all the filters including the blue and black tubes in the bottom, when it gets to the end of it’s cycle it smells hot because there doesn’t appear to be any water going through the rotating arms. It does appear to go through the wash cycle to start with, but when it’s hot if i try to rewash the items there doesn’t appear to be any water entering the machine. There are no kinks in the water pipe and everything looks as if it’s ok
for the machine to allow the heater to come on it must sense that it already has correct water level. if it has not then there is a fault in the pressure system. on the other hand, maybe it fills with water but the circulating pump isn’t pushing the water around the system.
Thank you very much for the advice. I’ve cleaned all the pipes & tubes. The lower spiggot that the horseshoe pipe attaches to had a partial blockage. Machine now works perfectly.
Thanks again for the replies, they have saved me a lot of money.
