zanussi dw905
  • #37273
    fasetester
    hi guys has anyone got a diagram of parts of a zanussi dishwasher model DW 905 how is the top metal spray arm attached to the top basket . thanks fasetester.
    #254204
    maltheviking
    Re: zanussi dw905
    You have PM 😉
    #254205
    fasetester
    Re: zanussi dw905
    hi guys can you get the bottom part that attaches to the top spray arm to keep it from coming off. the rotating shaft or do you have to buy the shaft with complete spray arm attched. thanks faseteter. 🙂
    #254206
    fasetester
    i know mal sent me diagram. but i cant see how the spray arm is attached thanks fasetester.
    #254207
    fasetester
    Re: zanussi dw905
    any one know thanks fasetester 🙂
    #254208
    maltheviking
    Re: zanussi dw905
    Hi Phase
    IIRR it all unscrews, sometimes they can be as tight as a Scotsman 😆 The nut is as diagram pt.527
    The parts diag. shows the nut under the venturi (127)but IIRR it is in the top of it, use long nose pliers in the castleations. Hope this is what you are after 😉 All parts are seperate, look on Connect’s under that model no.
    #254209
    fasetester
    Re: zanussi dw905
    thanks mal it is my mothers dishwasher the centre part with the nut. i can get it off ok. the bottom sits into the spray arm it looks as if there is a another piece that clips on to the bottom of the spray arm. i know the centre with the nut should be attched to the spray arm but it is not can i get the bottom part. thanks fasetester 🙂
    #254210
    maltheviking
    Re: zanussi dw905
    Strewth Fase come up for air mate 😆 you not got a fullstop on your keyboard?
    Parts are a cheap as chips, just replace the lot
    pt 50223756003 £3.00 ish. bit that clips onto basket
    pt 50223245077 £3.50 ish. bit that screws into spray arm
    pt 50657051004 £3.00 ish bit that holds it together (nut)
    Can’t give you anymore help for a couple of days cos I’m off sea fishing in the south of Scotland 😀 😀
