Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Zanussi DW907 heating element ?
- This topic has 7 replies, 2 voices, and was last updated 2 years, 10 months ago by
tonyb61.
June 3, 2023 at 12:19 pm #102005
tonyb61
ParticipantI’m not having much luck finding a replacement heating element for a Zanussi DW907 dishwasher. Does anyone know a good source for this part ?
thanks
TonyJune 3, 2023 at 12:29 pm #487127electrofix
Moderator1 has it gone, have you tested it ?
2 let me have the pnc number as i get 8 hits for that model
it over 23 years old so we may struggle
June 3, 2023 at 12:40 pm #487128electrofix
Moderatordoing a random search on one of them i get this one
https://shop.ukwhitegoods.co.uk/d355419-compatible-dishwasher-heating-element
but you need to check its correct
June 4, 2023 at 11:17 am #487129tonyb61
ParticipantHi, sorry for delay in replying.
The numbers on the dw are
Product no 91181036
Type 91181-1A
The main reason to suspect the element is the machine is not heating up and is cold at the end of a cycle.
Today I did a quick check on the element and it is not open circuit, though i didn’t have my ohmmeter handy to check actual resistance. I’ll do that later this week. But maybe not that then. I presume there is a thermostat that measures water temp to cut off the heater when temp has been reached, so this could be faulty ?
Regards
TonyJune 4, 2023 at 1:03 pm #487130electrofix
Moderatorok if the element is ok
you need to check both thermostats
then the wiring from the timerif all that is ok its most likley a timer contact failure
June 6, 2023 at 11:09 am #487131tonyb61
ParticipantHi Dave,
I popped around and measured the element at 21.9 ohms which looks about correct for a 2.5kW element.
BTW the pnc I quoted above was missing a digit it’s 91186103600.I took out the thermostat that is clipped to the steel bottom of the dishwasher washing chamber next to the heating element, and that shows a short at room temp, and opens if I put the metal case in hot water so that looks to be working fine. I couldn’t spot a second thermostat though ? Where might this be ?
Regards
TonyJune 6, 2023 at 7:40 pm #487132electrofix
Moderatorlooks like the other stat is in the door
June 14, 2023 at 11:14 am #487133tonyb61
ParticipantHi Dave,
As you predicted the other thermostat was in the door. I removed this, tested it and that worked too. So I put everything back together and decided to try the dw out, and it seems to be working fine now. I’ve got no explanation for that unless there was a dodgy contact that is now working. We’ll keep an eye on it and see how it goes.
Thanks for the tips !
Regards
Tony -
