Zanussi DW908
  • #25714
    S1MON
    I have been to this m/c today and it is doing a first fill with a wash. It stops washing and continues to fill then it will lock out. The next two clicks on he timer will do nothing and then the wash motor wil kick back into action. This is the same with all the programs.
    I have cleaned all the pipe underneath, cleaned the blue sypoon tubes and the sump. Ive tried a new valve and pressure switch but these havent made any difference!
    Im aware that this problem is usually pressure system related but it is totally clear. Done a few of these and never had this problem
    Any ideas
    #207310
    cab
    Re: Zanussi DW908
    after this occurs, what happens when you take the syphon tubes out to inspect them?
    cab
    #207311
    bobokines
    Re: Zanussi DW908
    Have you got a hairline crack in one of the syphon tubes?
    Bob
    #207312
    S1MON
    Re: Zanussi DW908
    well the syphons are totally clear, newly fitted with no damage
    cab: nothing changes when i take them out! should i try running without them fitted?
    #207313
    cab
    Re: Zanussi DW908
    no when you remove the tubes if water runs out of them it means the sump is blocked, on experience, there is a 10{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} chance that flushing the sump doesnt clear it and the only thing to do is replace it.
    cab
