Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › zanussi DW908 stops mid cycle
- This topic has 7 replies, 4 voices, and was last updated 14 years, 2 months ago by
slyp98.
January 23, 2012 at 6:19 pm #67525
slyp98
Participanthi guys had a look at this today its had little use ,customer sayes it stops mid cycle and when i checked it , no heat from the element , it checks out ok though 23 ohms , theres a stat or toc next to it and there is cont, there too power going to the element when in use also ? so i dunno i’m gonna replace the element anyways anyone had this kind of fault b4 cheers
January 23, 2012 at 9:27 pm #367702franz
ParticipantRe: zanussi DW908 stops mid cycle
Check Pcb for burning at the heater relay
FranzJanuary 24, 2012 at 8:27 am #367703slyp98
anyone have a tech sheet for this m/c thanks
January 24, 2012 at 9:46 am #367704AMS
Doesn’t this machine have a timer? Worth checking the wiring loom inside the door. If that’s ok, then considering what you’ve checked already, could be the timer.
January 24, 2012 at 8:12 pm #367705leavemetogetonwithit
Would it “stop” (= no sloshing?) just because it wasn’t heating?
I doubt it. Perhaps it’s not reaching the heating period before stopping.
Mike.January 24, 2012 at 11:31 pm #367706slyp98
i have to refer back to the original post , the problem being it has 220v going to the element but its cold , i cant see how this problem is something to do with the pcb , it has power at the element terminals , i didnt measure amperage but surely that wouldnt matter it has 220v !has to be carrying current also right ?
January 24, 2012 at 11:56 pm #367707leavemetogetonwithit
slyp98 wrote:there too power going to the element when in use also ?
Sorry, I interpreted that as meaning you had an indication with e.g. a “voltstick”, rather than your multimeter connected across the element. The control from pcb is usually in the neutral side.
Mike.January 25, 2012 at 8:33 am #367708slyp98
ah yes switched neutral mike,220v power to the pcb and then switched using a relay to the element thanks for that
