Re: Zanussi dw929
This all hinges on the product code.
There is more than one IWMS, (Tank Assy) and there is an inlet valve kit to suit either.
You have correctly identified the kit for the 2 valve IWMS but there is another for the 3 valve. The number of which I do not have to hand, things are further complicated by whether the semi transparent tube across the front is angled at 180 or 360 degrees. I’m assuming you are looking to replace the valve kit, if you care to plod around this site, the answer is on there as I gave this out a few weeks ago.
Alex
