Zanussi DWS 939 – not filling with water
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Zanussi DWS 939 – not filling with water
  • #8601
    longroom
    Hello.
    My Zanussi dishwasher – [Prod number: 911883002] will not fill with water when switched on.
    I have checked the filters within the machine,
    the inlet hose is clear and unkinked,
    the filter where the inlet hose connects to the machine is clear,
    and the machine discharge pump has been proved to work.
    I was toying with the idea that the water inlet valve might need replacing, am I on the right track or should I be looking elsewhere.
    thank you,
    Paul.
    #129574
    johnboy
    How old is the appliance. To be honest you would be better calling in Service Force as there are a number of issues that can cause this problem relating to a blockage in the Intergrated Water Management System on the left hand side of the appliance.
    #129575
    Re: Zanussi DWS 939 – not filling with water
    I would probably look elsewhere. Sounds like the anti flood has operated, often this is due to blockages in the air break/water softner chamber in one of the side panels. This is a complex device with many modified parts to cure this problem. Would recommend expert help really.
    click here to try our repairs@service
    #129576
    longroom
    Thank you eastlmark and johnboy, i’ll be taking your advice and will call in the experts.
