Re: Zanussi DWS39 Not working properly
It doesnt sound like a timer fault, more likely the inlet valve has locked due to a blockage if it is stopping completely, can you hear a faint humming sound from the inlet valve? if so:
Take out the filter, you should see a clear plastic dome with a screw in the top, under this are 2 blue tubes – these may be blocked. If they are then its likely that the hose underneath the machine is blocked as well. normally its in a grey cover & shaped like a horseshoe. You will need to pull the machine out & lay it on its back to reach it so obviously dont attempt any of this unless you are 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} confident at what your doing & make sure you unplug first. You may also need to reset the inlet valve, usually just removing the inlet hose is enough to reset, otherwise it might need a gentle tap.
The other alternative is to call an engineer, if its a blockage then your probably not looking at vast sums of money to repair it and most zanussi engineers love the sight of a machine with syphon tubes in it!
