Hey all,
Looking for a bit of guidance here. Went to look at the above d/w yesterday and its intermittently ceasing to move on. It will drain, fill and then stop, if moved on it will continue to wash as normal however it will sometimes leak (according to customer although I didn’t see this yesterday). I checked the element and stats, all ok. Cleaned out the IWMS system, which wasn’t bad. But it still stops at the same place. I then put a meter across the element as i moved it thru various stages in the wash but couldnt’ seem to see power getting to it. Ive checked all the wiring in the door but found no faults, and thats when . I ran out of time. Am i looking at a timer or is there something I’ve missed. I’m going back later and would like to be better armed.
Cheers
